Aller au contenu principal
Modèles A1297 Unibody : Début 2009, Mi-2009, Mi-2010 & Fin 2011
Questions au sujet de 544 Voir tout
Why can't I login? OS X with FileVault enabled
Can't login. Your home folder,which is protected by FileVault, didn't open.it needs to be repaired. To repair and continue logging in click ok. If I do that I get-your unable to log into the user account at this time. Logging in to account failed because an error occurred.
== Update==
Found original box: MacBook Pro 17/2.8/2x2GB/500/SD/AG
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
I'm trying to start up from install disk. Os x 10.6.4. Was using wrong install disk from my old PowerBook G4. Found right disk now trying to get to disk utility.
par
10.6.8 build 10K549 I can't get in past login screen to get Apple info.
par
Ajouter un commentaire
2 Réponses
Solution retenue
Do you have an external bootable drive? If you do see if you can boot up with it and then run Disk Utility from it.
== Update==
Here's a Apple TN on the recovery key: OS X: How to create and deploy a recovery key for FileVault 2. Without it you're out of luck getting in.
Indice 1
4 commentaires:
Correction install disk 10.6.4 Mac book.
par
Ran disk utility from install disk. Said drive was ok. Still won't allow log in .
par
Did you write down the File Vault key you'll need it to fix the drive.
par
Otherwise you'll need to wipe the drive down and re-install everything. Hopefully you have a backup.
par
You do not have to boot up with an external drive. Start up from OS X Recovery.
For such, you can just press Command R while starting up your Mac. Keep holding on until you see the circle that begins to load OS X Recovery. Let go your hold and wait till Mac OS X Utilities begin.
Click on Disk Utility. Select the drive partition where OS X has been installed. Click on Unlock and provide password because your disk is protected by Vault.
Now, you are ready to Verify Disk, Repair Disk, Verify Disk Permissions and also Repair Disk Permissions. You would like to do one at a time. Once alls done. You're done.
Quit Disk Utility, quit Mac OS X Utilities, and hit Restart. You will be good my friend.
Good luck!
Indice 0
7 commentaires:
Couldn't get to recovery. Tried to hold command r.
par
I can get to disk utility by booting up from my install disk. Ran disk utility. Where or how do I get to an unlock part? I have been running verify permissions,and repair permissions. On Macintosh hd and the other one is hitachi HTS.
par
You'll need to run FileVault to then plug in the key from the external disk.
par
Which drive do you think you have FileVault enabled? Highlight the partition of that drive. Once you highlight it (click on it), check the MENU on top. One of them (probably 3rd option) would be Unlock or similar. Also make sure your mounted OS X partition is grayed out. Grayed out means locked because of FileVault. When it's grayed out, it would not allow to do anything disk related. You must unlock or say decrypt it. If you see DECRYPT in the menu, you can do that as well. If you do not see menu, you can click on View from finder and then show Menu items. Hope it helps.
par
Puru, booting off the Recovery partition is only an option if the OP has 10.7 or later installed as the boot system. Only the last generation of Unibody 17" MBP (2011, Thunderbolt) requires 10.7; all the previous generations are 10.5/10.6. So far, Dan hasn't told us what operating system he's using (or which generation of MBP he's using), but he's been trying to repair the drive from a 10.6.4 install DVD. It's possible that the MBP only has 10.6.8 installed.
par
Voir 2 commentaires en plus
Ajouter une réponse
Dan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 12,142
