Aller au contenu principal
La cinquième génération de l'iPhone. La réparation de cet appareil est simple, mais nécessite des tournevis, des outils pour faire levier et enfin de la patience. GSM/CDMA en 16, 32 ou 64 Go / iPhone noir ou blanc.
Questions au sujet de 3017 Voir tout
vertical dead spot right side of display
I have an iPhone 4S with a dead spot on right side of entire screen, before everybody suggests bad digitizer, I just want to say I tried a few different screens with the same problem I even removed the logic board and put it in a working phone same problem. The problem is at the logic board level and I wanted to see if anybody knows which component is blown so I can replace it, bacause looking under a microscope there isnt anything obvious.
Répondre à cette question J'ai le même problème
Commentaires:
Have you used a meter to check the caps around the touch screen controller? There where I would start to after all the checks you already did.
par
Thanks , That is a good place to start!
par
Ajouter un commentaire
3 solutions
Réponse la plus utile
Check to see if there are any pins (female copper type) missing on connection from the lcd or digitizer. I had a similar problem with an iphone 5C and it was because I lost a few copper pieces from the connection.
Cette réponse a-t-elle été utile ?
Score 1
Commentaires:
Thanks for the effort Mark, but in the post I already mentioned I tried different screens, this is a logic board level problem.
par
Yeah. I meant on the logic board. There are the copper lining pins on the logic board side too. That's what my problem was.
par
Everything on the logic board is spotless, I guess start checking things with a meter.
par
Yeah hate to say it but you'll have to change the digitizer. I know you don't want to but sometimes it's cheaper to fix the one big problem than look at all the little things it could be. Sorry I can't be of any help, but best of luck though!
Commentaires:
please read the full post...
Thank You
par
Have a couple of 4's withte same logic board issue. Did you havr any luck testing caps?
Ajouter une réponse
Masterminds iRepairs sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 208
