Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire:
I have the same issue. Is there a fix?
par
Ajouter un commentaire
5 Réponses
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
Indice 0
Can you describe more precise what did you done?
Could be the aging of the accumulator?
Indice 0
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
Indice 0
1 commentaire:
Hi
What voltage do you use in capacitors?
par
Can be that the battery started to decay?
Indice 0
It could probably have an effect but it is not a reason.
Indice 0
Ajouter une réponse
smsoftware sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 2,258
