Adhesive will not stick
I just fixed a Sony Xperia Z and after a little while the adhesive does not want to hold the screen in some places. Do i need to buy a better adhesive?
This seems to be a big issue with S5's and Sony Experia's. Best thing to do is to make sure you thoroughly clean frame, apply a plastic adhesive activator and use high quality adhesive's. Also you need to check your frame/chassis for damage, separation, and or whether or not its bent. We've been looking for a supplier for Sony Experia OEM water proof adhesive. If anyone knows where to get it can you please let us know. Thanks
heat it up with a hair dryer carefully, then put it on its back facing down, put a little weight on the top and leave to set. as mentioned above make sure the bezel is clean from the old adhesive, there is a glue that does help called B7000 we sell this on our site and its a great glue for this type of job, not corrosive like superglue and its flexible at the same time.
Glue B7000 where can i find it, i can't find it on his site
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 603
1 commentaire
I have used kitchen silicone. I have changed this phone display 3 times works every time :)
par Andris Viimsalu
