Aller au contenu principal
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Questions au sujet de 54 Voir tout
Why is the power of my 3 tb time capsule dead
my power adapter was overheating . for the last 3 day . now the power won't come one at all . went to a apple store they tell me it will coast $ 299 to repair .
can the power supply be change or repair ? can't the 3tb drive be salvage for something ?
Update
serial C86L6FXRF9H5
WHERE CAN BUY A NEW POWER SUPPLY ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
What do you mean by "Power Adapter" here. This version of AirPort has a built-in power supply. Are you sure this is the model? Can you give us the product number so we can verify.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Given how easy this system is assembled there is no direct guide to replace the power supply. Here's the the IFIXIT teardown: AirPort Extreme A1521 which is the exact same unit as the A1470 hardware wise.
As to the power supply you'll see in in Step 13. But before you go there I suspect your real problem is the fan unit seen in Step 12 and the buildup of dust.
I would start there clean the dust out if you haven't already and carefully test out the fan making sure its working.
Here's the Power Supply part: eBay: ME918 Power Supply
Indice 1
1 commentaire:
I've followed the tear down instructions to try identify the power issue with my 1470 also as it doesn't even get an indicator led when pluggin into power so assume it's the power supply not the fan, after dismantling the fan was a little dirty but still spins, how do I tell if mine is power supply or fan that is the issue?
par
Ajouter une réponse
sgt996 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,098
