Aller au contenu principal
Improved second generation Google-branded tablet with a 7" screen.
98 questions Voir tout
Nexus 7 (2013) Screen is Black. (Can still hear notifcations)
My Nexus 7 (2013) screen and charging port have both been replaced professionally. Following the charging port repair, the tablet worked at the store, but later the next day when I went to turn it on, the screen didn't turn on. I thought it was just dead so I put it on the charger. I went to check it the next morning and it still didn't turn on. I've tried all of the reset solutions I could find and the most I've been able to do is get the power/system light to blink five times. It will also occasionally produce notification sounds from various apps and my Google Play account shows that is has recently been online - I just can't see anything! Any ideas on what I should do to further troubleshoot this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
This will one of two thing.
1) The LCD cable is not in place right.
2) The LCD has gone bad.
I am thinking your issue is the first one. If you can open the back you see a gold cable. This is the LCD cable.
First make sure it is making a good connected to the main board. If it is then take a small Philips screwdriver
and look under the charge port board to see if the cable is connected the right way. If this cable is connected the right way on both end then it's the LCD and it will need to be replaced.
Indice 3
2 commentaires:
Just stumbled across your reply. Thank you SO much! Followed your first suggestion, and you've fixed my Nexus 7!!
par
Awesome, my boy was gutted when he fell with his. Thought he would be in trouble
par
Thank you so much! Sorry for the late reply. I will try it!
Indice 0
Ajouter une réponse
Samuel Lovell sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 408
