How To Remove Stripped Screw
If the screw head protrudes out from its surroundings you may be able to use a needle nose pliers to rotate it by grabbing the outside of the head or you may be able to use a small cutting bit to carve a slot for a flathead screwdriver.
If the screw is flush with its surroundings or sunken in, use a rubber band, place it between the screw and the screwdriver, and press down HARD while rotating.
I like to build a ball of solder on the top of the damaged screw then rotate it out with a pair of needle nose pliers. This works well on iphone screws that get stuck
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 259
https://www.youtube.com/watch?t=10&v=SEZ... this video will help me!!!
par Fealbert Pajunar
