I had the same problem: Nokia 7 Plus, dropped into the toilet, the phone seemed to work except the touch screen did not respond to touch. I took it to a trustworthy repair shop (Fonum in Finland), and they had a look at it and said that it couldn’t be fixed.
However, my father-in-law insisted that if we soak it in isopropyl alcohol it would work (I think the idea is that isopropyl alcohol replaces the water, and eventually evaporates). As we didn’t have anything to lose we tried it out and it actually worked: the screen is now responding to touch, and the phone seems to work perfectly. The only downside is that the screen is now kind of messed up — looks like there are small amounts of liquid under the screen, and some other discoloring in parts of the screen — but I guess we could now replace it.
Thus, if you really need to get your phone working and nothing else works try to soak it in isopropyl alcohol. It will mess up your screen but it might make it responsive again. Note that we did this ~2 weeks after the water damage had occurred so you don’t need to try this as your first option.
****UPDATE****
A few days later, the screen is completely dead. The phone still works though (connects to a computer etc.)
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
12 commentaires
What did you finally do to fix your screen Rosalind?
par Shruti Saxena
My mobile also have same problem
par Manunath reddy
My tablet did not fall in water but something filled with water spilled on it. It was cracked up b4 this incident but the touch was still working. All the knobs are working (power button, volume buttons and home button) . it's coming on and I still get notifications but I have a pattern on it my touch is not responding.plz help. :"(
par It's Aisha
My phone touch is working easily but last line touch is not working so how can I use my phone?
par Neeral Patel
My phone fell down from my hand there is a small crack as well. My screen isn't responding properly.e.g if I press "g" it wrongly types "q" or something else. If I keep my screen on and leave it the automatically starts working. Can I do anything at home.
par Manish Bhatter
Voir 7 commentaires en plus
