Aller au contenu principal
Tutoriels et assistance pour réparer son sèche-linge.
869 questions Voir tout
Question close
My AEG T86590IH dont heat
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Thanks a lot! That was a savior
par
Ajouter un commentaire
1 Réponse
Solution retenue
Kostas Damianos , check your vent first. Make sure it is not obstructed. There are many reasons why it may not work. A few are:
An open fuse/breaker in the house fuse panel. Check your outlet to make sure that you have 240 V on that. Use proper precautions and tools when doing so.
An open thermal fuse in the dryer, or a burned out heating coil. For that you will need a multimeter to check.
Open switches which can include the heat selector switch mounted on the console panel, one of the thermostats mounted in various locations as well as the motor switch and of course the timer or relay on the control panel. What have you checked thus far. Post some images of the back of your dryer with the cover removed and showing the layout of it.
Indice 1
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 117
