Aller au contenu principal
How to repair or replace the rear derailleur
I found a 18 speed Roadmaster Neutron bicycle in much need of repair. The rear wheel & derailleur have been partially removed & are hanging loose by the side of the frame. I'd like to safely clean & reinstall correctly. Any advise would be appreciated.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Solution retenue
The following guides show how to remove and replace the rear wheel of your bicycle:
And here are a couple guides to help you fix or replace the rear derailleur on your bicycle:
Though not your exact model, check out this device page for a Roadmaster bicycle that may be similar to yours. On that page you'll find links to more guides that might come in handy as you repair other components on your bike.
Hope this helps!
Image Specialized Expedition Rear Derailleur
Tutoriel
Adjusting the Rear Derailleur
Difficulté :
Modérée
30 - 45 minutes
Image Specialized Expedition Roue arrière
Tutoriel
Remplacement de la roue arrière
Difficulté :
Facile
2 - 5 minutes
Image Trek 4300 Bicycle Rear Wheel
Tutoriel
Trek 4300 Bicycle Rear Wheel Replacement
Difficulté :
Modérée
Image 2006 Iron Horse Warrior
Tutoriel
How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables
Difficulté :
Très facile
10 - 20 minutes
Cette réponse a-t-elle été utile ?
Indice 1
Ajouter une réponse
robertwente sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 478
