Aller au contenu principal
Quatrième génération d'iPad, annoncée le 2 novembre 2012, disponible dans les modèles 16, 32 ou 64 Go. Numéro de modèle A1458.
218 questions Voir tout
How to fix ipad 4 wifi digitizer problems
how to fix ipad 4 wifi digitiser problem i bought this part : iPad 4 Screen Digitizer Assembly
so how do i fix it do i have to do anything diffrent or should i just follow this guide Remplacement du panneau frontal de l'iPad 4 Wi-Fi>?
Image iPad 4 Screen Digitizer Assembly
Produit
$39.99
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
I have done 3 of these, just follow the instructions; Pre-read instructions first. Make sure you understand them fully. Take your time, heat the warmer often and WEAR SAFETY GOGGLES: glass flies everywhere when it cracks.
Before removing any of the protective plastic coverings (inside and out) and the adhesive backing pre-test. As an Apple Tech - the white lines on the digitizer should not be visible when fully inserted into the connector.
Place the LCD in-place with screws, then gently place the digitizer on top of it. Turn it on and make sure all corners, center bottom, etc works properly. test cameras, microphone and speakers, and Wifi, buttons, volumes, etc.
Indice 0
Ajouter une réponse
manazir hussain sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 153
