Aller au contenu principal
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 questions Voir tout
Question close
Whats the best heat to open when model?
I am doing repairs at the flea market and those type of events and need heat to loosen the adhesive but I will not have access to an outlet and need to know whats the best open to listen the adhesive i would use the iopener if I had access to power please help.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
You are looking for a heating source without electricity?
I am not sure there is one. Is this an outdoor market where you could have access to your car? A power inverter hooked up to your car's battery would be ideal. Otherwise you will want to look into bringing batteries with you.
I just can't think of a possible way that doing repairs at a flea market would be a good idea. You need power to do repairs right. At minimum you need a heat gun and light. There is also the issue of dirt and dust.
I hope it works out for you but I'm just not sure how you would make this work.
Indice 0
3 commentaires:
If I use a power inverter, how will I make sure the battery in the car does not die.
par
Buy a deep-cycle marine battery and a carrying case. Get the biggest one you can carry. Gel-cell type or lithium.
par
I don't know how much heat you need, but maybe a 12-volt hair dryer to go with the battery? No need for an inverter then.
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 62
