Aller au contenu principal
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 questions Voir tout
How do I change the number of rings?
how do I change the number of rings?
Répondu ! Afficher la réponse J'ai le même problème
Indice 10
11 commentaires
D1680 Series how to change number of rings
par
it has always worked before.and we do have the answering machine function. DWX337 Waterproof Accessory Handset users guide. help not responding when we call posted numbers.
par
I need to know how to change number of rings for a D1788-2T
par
I do not have the model you answered above. I have a dect 6.0 with answering capability
par
par
Voir 6 commentaires en plus
Ajouter un commentaire
3 Réponses
Solution retenue
Hi @ n.marous,
In standby mode go to Menu > Answering Setup > Ring Time and select either 2, 4 or 6 rings.
Here is an auto download link to the D1788-2T User manual which may be of some help. Scroll to p.18
Indice 2
1 commentaire:
Thanks a lot for tips. at and t could not help me with this ptoblem
par
This is only possible with Uniden phone versions that come with the Answering Machine Function. The Phone version you have listed here is a D1760-2 which does not have an answering machine function. Unless yours does then please verify that the model number is correct.
Best!
Indice 1
2 commentaires:
My model is Dect 6.0 P.Rabe
par
E209700 is my uniden cordless model number. I want to set the ringer to 6 times before it goes to answering machine
par
Hi @thilary311,
Unfortunately your model phone doesn’t have any options to extend the ringing time. You can only temporarily silence the ringing signal for one call. The phone will ring again on the next call.
If you have a Voicemail feature connected to your landline phone service you may be able to extend the ring time before the call diverts to the Voicemail box. It might depend if you are on the maximum amount of time already or not. Usually it defaults to a lesser time, so you may be lucky
You would have to check on your landline phone service provider’s website how to do this as each provider has their own method. Alternatively, contact your landline phone service provider’s customer service section and ask them.
If you don’t have the Voicemail feature connected to your phone service then the ringing time may be adjustable, but again you would have to check with your landline service provider as above.
Indice 0
Ajouter une réponse
bobrosie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 86
Total : 20,570
