Add a second drive SSD or HDD, none currently exists
I need to get a bracket and cable to add a second SSD or HDD to my iMac 27 2013 model. I have now purchased several parts and pieces and none are working. I got the temp controller from owc but no bracket to be found. I also am clueless as to where to even plug in the sata cable on the board itself. I have watch videos and read through the forums with no luck. I have disassembled and reassembled several times just to find each time that the new part I got is not what i need. It would be really awesome to be able to add the new 5gb 3.5" hdd or add two additional SSD's in its place. My iMac is held together at the moment with tape and looks horrible :(, i don't want to waste the new double sided tape on another fail. Can someone please help with details, part numbers, links etc... so i can get this job complete. I'm embarrassed to ask, but I really need some assistance. Thank you in advance for your time.
Can you clarify what have now and what you really want. Remember this system has one SATA port and one M.2 type blade SSD connection. So you do need to limit your self to two devices here one which will be the blade SSD. You could swap out the HD for a SATA SSD or you could swap out the HD with a larger HD drive from what Apple installed.
par Dan
