Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Does anyone have had a problem with a burned board?
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
par oldturkey03
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
par vincenthink
