The screws DO have T10 Torx heads. There's just a tamper stick on top of the screws now hiding it. There's no need to wreck the screws and the bracket (which apparently you did) with any kind of brute force with needle nose pliers. All you have to do is use the T10 screw driver and apply pressure to the middle of the "blank" screw. The T10 screw slot will reveal itself when you apply enough pressure, and then you can simply screw them out. You can definitely re-use the screws afterwards. It's just a stupid black tamper stick that they stuck on top of the T10 torx screw. So definitely do NOT listen to Jon Spinella's advice and wreck your screws and bracket.
A voté
Annuler
Indice
0
What do you mean it's changed shape?? The screws are Torx screws (T10). Are you using the correct screwdriver here? Some poeple confuse the Torx for Allen or Spline which are different.
par Dan
There are also T7 screws. How about a picture or tell us what step on the guide you are having issues with. Did you strip a screw out?
par mayer
I know this is old but for anyone else seeing this, the screws no longer have T10 torx heads. They are flat, no holes, no slots and you'll need to carefully use needle nose pliers to remove them (and replace with T10 torx screws like I did). I replaced the entire bracket and screws since they get a little scratched up during removal. Be very patient and careful to not slip and damage something on the board.
par John Spinella
@spudnuts where did you get the t10 screws and the bracket???
par Carlos Blanco
I would like to know where did you get the t10 screws and the bracket also
par timmy123
Voir 2 commentaires en plus
