Using iMac Case for a PC
Hi everyone, I own an old iMac 20" Core 2 Duo 2.16ghz (model Number A1207) that i loved for it's design.
The iMac, as many of his generations, had the vertical lines problem, Hdd drive problems, and a faulty ram module so it's actually unuseful. But i can't simply throw it away.
I would like, as an hobby, reuse the case, putting inside a miniatx pc ad using the display. Do you think it's a possible operation?
Is it possible to find an adapter for the display cable ? i think the PSU unit could be reused because a MicroAtx pc should use very low energy and for the AUDIO/USB/FW/Ethernet port, simply use an extended cable to reach the ports on the rear.
What do you think ?
