Hola, mi tablet (prestige elite 8Q, model:ME-8Q, FCC ID SI9PRESTIGE8Q, MEMORY: 8gb MADE IN CHINA), cuando lo enciendo, no me carga a la pantalla principal, sino que, lo que me aparesce es el simbolito del sistema androide y al lado una linea, me piden que escriba una contraseña en la misma, pero no tengo idea a que contraseña se refiere, porque incluso yo no tenía ninguna contraseña en mi tablet. Lo he reinicido de fábrica, lo he llevado a distintos lugares y nada. (“nota”:cuando la bateria está baja puedo hacer un procedimiento y acceder a la configuración. Muchas gracias y por favor necesito de urgencia que me ayude.”necesito saber que contraseña poner o que tengo que hacer”.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
18 commentaires
I have the same problem! Where can I get another charger to fit and work? My tablet is a Prestige Elite 9Q 1 year old !! This is disappointing because I really like this tablet ! Evergreen Park IL. Thanks Kris Tyszkiewicz
par Kristen Tyszkiewicz
Hi. I also have had same problem..This is the 2CD visual land tablet I have had from H S N..first one charging quit working .Was happy with other features of tablet .thought it was something I had done..ordered another visual land and now same problem..this time little pieces of charging area fell out..No children here to touch or mess with it.It felt loose when I first got..should of sent back ..
par sheryl
I have the same problem with visual 2 bought a few months from HSN tried to charge it for days I have ins. on I need to get a better and new charger. this is a big disappointment on behalf of H S N and visual land
par Adelina Casseus
Visual Land should not get away with selling shoddy merchandise. I paid $140 for my piece of junk that lasted 3 months. Government needs to investigate this co.
par lyrehaf
Same problem after charging in only 3 times. It's like the port. Does not accept the fit of the charger cable correctly or something. I can jiggle it and get it to temporarily work, but then it stops. VERY IRRITATING!!!
par ncjocn C
Voir 13 commentaires en plus
