Aller au contenu principal
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
Questions au sujet de 71 Voir tout
The horn does not work
the horn does not work
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
fuse is not blown but horn still does not work
par
what else could possibly wrong with the horn
par
Ajouter un commentaire
4 Réponses
Solution retenue
Sam Mazzolino, could be a horn issue as well as a blown fuse, the horn relay or even the horn button itself. First check the fuse. Make sure that it is good. Then apply 12 volts to the horn directly and listen if it works. Some instructions on here If it does, you know you are having a power issue. Check the relay next. For more information about the relay location etc. We'd need to have the exact year of your Corolla.
Indice 2
1 commentaire:
my car is 2006 toyota corolla
par
I normaly only work on domestic autos however this is simple. Check your owners manule for the locations of all fuse banks. Next look for any fuse related to your horn. Check each one for a bowen fuse(burnt center seperated metal strip). Replace with like fuse I.E. 20 with 20. Note do not replace with greater or lesser fuse, you will damage your electrical system. If all is well an no horn then compleatly disconect the batery for three minuts an reconect snug. If still no horn run a code reader to see if the car tosses a horn code. If no horn, fuse problem, and or code take it to a Toyota delership, this should be fixed for free or up to no more than $199.00. I know you should go directly to a code reader however not all of us are rich enuf to buy one or to go right to the dealer. This is the best way to go about any auto problem before flushing away your bank acount. I hope this helps.
Indice 1
My Toyota Corolla verso diesel 2008 car's horn is not working please tell me how I can fix it myself. Thanks
Indice 0
If the fuse is good and the horn it self is good, then it should be from the horn and srs connection under steering
Indice 0
Ajouter une réponse
Sam Mazzolino sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 69
Total : 18,808
