Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, informations sur le démontage et le diagnostic de la deuxième génération d'Apple iPad avec réseau de téléphonie mobile 3G GSM (AT&T), disponible avec 16, 32 ou 64 Go de stockage. Équipé d'un processeur dual-core A5. Commercialisé en mars 2011. Identifié par le numéro de modèle A1396. Les réparations nécessitent l'utilisation de chaleur et un levier prudent.
Ipad 2 is not charging, no turns on, black screen
Hi,
my Ipad2 GSM does not charge and does not turn on. (Working properly before discharging)
The charger and the cable were tested and working properly.
The connectors are clean and without damages.
By connecting it to a PC is not recognized
Ideas on what might have?
Thank you
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
6 Réponses
Have you ever charging for too long? It is likely a hardware problem like mainboard is broken.
Indice 0
No, I have always paid attention to the charging time and I never left the device on charge more than necessary.
Before it was fully discharge by connecting the charging cable appeared to me "device not in charge" but the cable and charger are ok.
It is not possible that it is damaged (for some reason) the flat cable between the charging connector and the battery or connector or something similar? unexpected death of the battery?
Indice 0
Have you tried resetting it by holding the home and power button at the same time for 10 seconds ?
Indice 0
Yes, I tried but no response and no Apple logo (although I think it's due to the fact that the battery is low). Other ideas?
Indice 0
Some other tests or possible causes of the problem?
Indice 0
2 commentaires:
Have you tried a reset or DFU mode ? Were there any symptoms of a problem before this happened? Crashing? Quick discharge of the battery?
par
I tried it but the combination power + home gives no result, by connecting the device to the PC is not detected and never gave any sign of abnormalities or sudden blocks.
It reported that the battery was used as normal and once the discharge everything and as if you are unable to charge more
par
Is there any answer?
Indice 0
Ajouter une réponse
ModMatrix sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 1,091
