I can't get the car out of park
My mustang shifter quite working a day ago. My button no longer allow me to shift to any gear.
Car: Ford mustang 2000 automatic
Before you get to far ahead here and start to tear things apart try wiggling the steering wheel back and forth while you work the shift lever the steering lock can affect the shift lever if its hard against the lock so moving the steering of the lock can release the shift lock.
If this doesn't work then you need to check the shift lever itself for issues and also the cable that runs from the shift lever. Fraying of the cable ends can cause the shift lever to bind and not work. To check both you'll need to remove the council around the shift lever .
I had the same problem with my 03 mustang. It was a safety mechanism if your brake lights are not working it will not shift into gear i had to run wire from battery to switch behind brake pedalthen run another wire back to the brake light only thing now is if my foots on brake my left blinker wont blink until i let off brake
I have the same problem with my 04 mustang 3.9v6. It will only come out of park when the key is turned to start. It will not come out with key just in the on position.
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 44
Total : 12,802
