Won't boot. Tried troubleshooting ram, worked and dead again
Ok... So I am at my wits end here. I have a a1278 macbook late 2008. I have a relatively new battery, new power cable, and 8 gb of ram with 2 sticks. I also have replaced the keyboard before.. Which was a pretty intensive task.
Here is my issue. My mac stopped booting up and I assumed the ram, motherboard, or hard drive. I put it aside for a while as I didn't want to dump more money into a old machine. Well, I still am not at a point I want to jump on a new computer so I figured I'd try fixing again. Tonight I took both sticks of ram out, held down power for 10seconds, let up a second, then held down again. To my surprise it started beeping no ram! I was incredibly excited. Put a stick back in. Put the back back on and did the same power cycle. It booted!
I thought I would see by trial and error if I had a bad ram slot, a bad stick of ram, or if both would work. Tried adding both. Dead. Tried one. Dead. Tried the other. Dead. Even without ram in I can't get it to beep again.
So, any suggestions? I'm confused as to why it booted and now won't. Also, it took quite a while to run any tasks when on the short time it was working. I could view files on the hard drive so I am assuming that the hard drive is not my issue.
Thanks for reading and any suggestions you might have.
What does your battery indicator light show?
par mayer
It is orange when charging, but green if I plug in without battery.(when it briefly was running I saw the battery was around 70%)
par Richard r
Sounds like you have upgraded the RAM. Please give us the type and speed of what you put in. Also the last four figures of your serial number.
par mayer
