Internal memory. Saving files.
The telephone does not work. How to save files to the internal memory?
Windows9x the files are saved to the "internal memory". Since you are saying your phone does not work, I can only wonder if you are referring to getting to those files. You cannot unless you fix your phone.
Okay. Look. Phone down, now is not included. Motherboard without visible damage. Everything is as new. The battery on the motherboard with traces of oxide. What should I do next?
Ok. How to change the battery on the motherboard?
post an image of your battery and the corrosion with your question.
When connected to a PC, it's defined as the "test B\D" Boot fall?
Looks like substantial amount of corrosion. Remove the battery and carefully inspect the small SMD components next to it. There may be more corrosion giving your plenty of trouble.
Broke.
Not really, resolder the battery connector et al.
Okay. Thank you for your help. Though all the same. The telephone does not work. To change the motherboard? But I need my information.
If you change the board you lose your information. Try to fix it.
If the PC sees the phone as "Test B/D". Maybe it's the loader?
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 76
