ny speedometer is not working but rpm and gas gauge work
Speedometer not working
Replacing a speed sensor entails 2 bolts and a electrical end this is a common problem with Hondas and Acuras
https://www.youtube.com/watch?v=OZp7xoeF...
This video can help guide you through the process if you are so inclined. the video is for a Honda but they are virtually the same car .
Hope this helps
those are all different sensors in your car, the gas gauge is a float in the tank, the tachometer is in your engine and the speedometer is on the transfer case, you are going to need to take it into a shop to get the sensor changed because they would make sure your car is reading an accurate speed after they fix it
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5,243
1 commentaire
Probable broken cable
par kent norton phd
