Aller au contenu principal
L'eMac est un Mac G4 tout-en-un conçu pour le marché de l'éducation. Il est le dernier mac à utiliser un écran CRT et a été vendu à un faible prix aux écoles et à d'autres institutions.
Questions au sujet de 47 Voir tout
replacement of the power button
need to replace power button anyone can help with schematic diagram?
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Here's a list of the eMacs. Just click on the one you have to get a diagram of the parts: http://www.welovemacs.com/emsepa.html
Indice 1
1 commentaire:
I am including a link on taking your emac apart. To replace the power button you need only to remove the case. +
http://www.wilko.com/emac/
par
Please be extremely careful when opening eMac.
NEVER touch anything above the Digital Assembly without one hand safely behind your back (thought the ONLY thing you should be touching in the Analogue Assembly is the power connector on the right side of the unit).
I'll gladly assist in the eMac's burial (I've had about enough cuts repairing these things!) but I don't have a hole big enough for you too!
eMac power buttons seems to have a habit of deformation as they age; poor repair technique can also contribute to early death. If you haven't done so already remove the back housing. Note: when removing the rear housing, slowly lift the rear housing. Reaching from the Digital Assembly side up to the power button, remove the low voltage power cable from the power button. Remove the rear housing.
Inspect the power button for deformations of the metal support and any foreign objects that could be interfering with operation. If no defects are apparent very carefully remove the button from the acrylic housing for further inspection. Obviously this is a very simple module; if you have more TLC than green to burn you might be able to repair it.
Good luck and BE CRT SAFE!
Indice 0
Ajouter une réponse
Andre sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,129
