Why is my device constantly power cycling?
The device will charge fully and drain to 50% than die almost instantly...
Most likely this is an issue with the connection of the battery. Try disconnecting the battery internally and then reconnecting it.
how do I open my tablet
@cabrich1957 Assuming we're still talking about a The Trio Stealth-10 tablet, there's a battery replacement guide available here on iFixit.
Trio Stealth-10 Battery Replacement - iFixit Repair Guide
Unfortunately, Ian Russell's solution isn't a great one, as the battery doesn't use a connector that can be unplugged; instead the battery is soldered directly to the motherboard. So you'd need to use a soldering iron to disconnect the battery and reconnect it.
If you're experiencing the same issue as the original poster, I would disagree; this sounds very much like a battery that has reached the end of its useful life and needs to be replaced. That would be the first thing I'd try in order to fix the issue.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 237
