Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
No power, replaced battery, battery is not charging when plugged in
I have a Galaxy 10.5 (SM-T800) that I picked up to repair. It had no power when I bought it, battery was below 3 volts so I replaced that first. Left it to charge overnight and found that the battery's voltage had not change. I can't get it to power on at all, tried hard reset with the buttons (Power, Volume up, Home) and no response. Tried multiple chargers and cables they all work, swapped the motherboard with another SM-T800, though I can't know if that one is any good either. What am I missing? Would it not turn on at all if the charging port is bad? I have a new charging port on its way but even so with a good battery at the right voltage it should turn right on. None of the water stickers show any evidence of water damage either. The screen is not cracked and it has basically no marks on it anywhere, so it probably wasn't dropped.
Any help or input would be really appreciated, thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
6 commentaires
Please if you fix this can you post how?? Have same problem, new battery fitted, not chargers etc... , can't see it being charging port stopping boot up with tested new battery. Many thanks in advance
par
Same problem here. I will never buy another Galaxy again. Big mistake. iPad and iPhone did there stuff right. I'm no fan of apple but Android is garbage compared.
par
Mostly its the battery conector solder cracked not visible without magnifying glass or microscope its a common samsung tab problem specially if you try to pull out the battery. I have fixed already 4 tabs with all same issue, hope this tip helps you out
par
Have you got an exact location where this connector's solder may be cracked Len, may give it a bash, if it's only a dry joint!. Tab just sat in the drawer at the moment. Took it to local mobile guy in the market, he reckoned it was the motherboard, which to me means BER. Tks
par
watch this tutorial by clicking given link you will get somthing...
https://youtu.be/sNcCabxmqiY
par
Afficher 1 commentaire en plus
Ajouter un commentaire
4 Réponses
Solution retenue
Turns out it was the charging port. I put in the new port, plugged it in and immediately got the charging screen and was able to turn it on.
Indice 2
That's fantastic news for you Ant. Going to order a new charging port now, hopefully with the same result. Many thanks for your share of information.. Nige
Indice 0
i have the same problem,i did all what is suggested here but nothing is happening.is anyone with a schematic diagram i can use for reference, please post it.
Thanks
Indice 0
1 commentaire:
yeh, schematic is needed instead of throwing parts at it
par
Heb Ander problemem laad alleen op als tablet uit staat met Ander moederbord laad hij well op als hij aan staat wifi chip problem hoe to flashen???
Indice 0
Ajouter une réponse
Ant sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 31
Total : 5,717
