On my Samsung,I had 3 SMALL vertical lines-2 in the center,1 on the left.After investigating,turns out it was the ribbon cables going into the screen. I needed to remove the bezel and top of the screen frame to access the ribbons and gently “diddle” them.The lines would disappear,and by placing a cardboard wedge under the ribbon,it would ultimately “fix” the lines.However,I do resell these sets,and dont want a cheesy fix TV coming back to me. A new t-con board wouldnt fix these lines. Basically,once you start seeing lines,your LCD panel has gone bad.Anything from the video driver boards on can not be replaced as they are hard wired and pressed at the factory.Diddling the ribbons into your screen panel itself may work,but its a cheesy fix.Im going to scrap this TV out.
A voté
Annuler
Indice
0
16 commentaires
i hit the side for a while it work .but now thats no good
par keithstowers90
Help vertical lines on my led computer
par Tmawia
@tmawia lets start off different here. You need to ask your own question. So use this link https://www.ifixit.com/Answers/Ask and give as much detail as possible. The more detail you give the better your chance to get it repaired. Right now it sounds like a bad LCD :-)
par oldturkey03
Vertical lines on my led computer it started last year. It began to vanish after some time but they keep on appearing please help
par Tmawia
Got this on my Lcd TV
par josh
Voir 11 commentaires en plus
