Yes, it does sound like the optical drives SATA cable is bad here or the ports logic.
You may want to review OWC: Data doubler page. While you have someone else's unit they all have the same problem due to the system controller chip Apple used. In your case you have a MacBook Pro 15" 2.53 GHz Core 2 Duo {MacBookPro5,4}. Here is what OWC states:
2008/2009 MacBook/MacBook Pro 13", 15", and 17" models. (Model IDs: MacBookPro5,1; 5,2; 5,3; 5,4; 5,5 and MacBook5,1; 6,1; 7,1) While a 6G SSD does function, it will only do so at SATA Revision 1.0 (1.5Gb/s) speeds rather that the SATA Revision 2.0 (3.0Gb/s) speed the machine can deliver. Should owners of these machines desire another SSD option, the Mercury Electra™ 3G SSD does run at the full SATA Revision 2.0 (3Gb/s) specification.
Basically your Optical drives SATA port is only SATA I (1.5 Gb/s) in this model. So you are limited to drives which are compatible with SATA I. The original Apple drive is a SATA II (3.0 Gb/s) and may have problems running here in the optical drives SATA connection. I should also point out the crash guard protection Apple has in their systems is only within the HD SATA connection. So moving the drive over you loose this protection.
Frankly, I don't recommend doing dual drives in this system given all of the issues here. I would recommend going with a SSHD hybrid drive Seagate laptop SSHD replacing the HD alone. Then you gain the performance of the SSD and still have the deep storage of a traditional HD. Or, if you can swing it get a larger SSD alone and be done with it.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires
which adapter did you get ? i believe you have to get ones that are designed to work with macs
par smai555
The adapter is designed for Mac (see link to Amazon - http://www.amazon.it/gp/product/B00A2VNU...) but I don't think that is involved.
What really bugs me is that the Superdrive did not work in its place inside the laptop but it does if connected externally via USB. This is why I thought it might have been a problem of connections or cables.
I also tried the reset of the SMC and PRAM with no success...
par PM
