4.7l dodge timing chain tensioners can,t get pumped up
keeps jumping time just put knew heads
Répondez à cette question J'ai le même problème
Commentaires:
Alton, what year is this engine? what model does it come out off? why did you change the heads? Did the timing chain jump before?
par
is the timing chain skipping or is the distributor not mating with the cam and are you talking about the pump connection to the distributor shaft?
par
Ajouter un commentaire
