Aller au contenu principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Questions au sujet de 892 Voir tout
Vizio light flashes no picture
I have a vizio xvt553sv when you try to power on the t.v. The vizio light on the front just flashes. I've tried a power cycle but the television still will not turn on.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
I'm having the same issue now. Black screen, directv is still audible, and the t.v. cycles itself on & off with a blinking power light. Vizios blow!
par
Ajouter un commentaire
6 Réponses
Réponse la plus utile
I've replaced a few capacitors on my older tv. One was hard to find, they usually show a burn mark. If you have a multi reader and patients you will find it since there are quite a few of them. Soldering skills are necessary. Good thing s capacitors are cheap.
Indice 1
Try unplugging the television, holding power for 30 seconds, then replugging and see if it turns on. If not, a capacitor may be blown on the PSU board, and you would either have to replace the capacitor or the whole board.
Indice 0
1 commentaire:
I have the same problem any help please
par
I replaced the whole board and are still having the same issue
Indice 0
I had the problem. We unplugged it. Waited 30 seconds. Then plugged it back in, then repeatedly tried to turn it back on. Eventually, about 5 or six times, it came back on. Be patient with the on button.
It worked for me. I hope it works for you
Indice 0
replaced the PSU… no Luck.
Just ordered the T-con board
Indice 0
I am also currently experiencing the issue. Last time I had the issue I unplug the TV for a few hours and then went back to it and it happened to work. I believe the problem was caused by plugging a USB fan into the TV so that it could help keep my xbox cool without needing another USB port over there. Using the fan wasn't a problem until I turned the TV off and tried to turn it on again. I hope this help somebody. Say a prayer for me and my TV will wake up.
Indice 0
Ajouter une réponse
patriciaalvarado94 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 66
Total : 19,139
