Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et de dépannage pour la série Presario CQ58. Il s'agit d'ordinateurs portables économiques fabriqués par Compaq, qui a appartenu à HP de 2002 à 2013.
How can I reset password?
How do I reset my password
Répondu ! Afficher la réponse J'ai le même problème
Indice 7
7 commentaires
What version of Windows are you running?
Does it matter if you retain the data , or are you ok restoring it to factory settings?
par
I have windows 10.1
par
I need to retain my data
par
My laptop is Windows 8.1
par
I have a compact presario CQ5500F PC IT HAS LOCKED DUE TO SOMEONE RESETING MY PASSWORD HOW DO I GET PASSED THAT AND RESET MY PASSCODE
par
Voir 2 commentaires en plus
Ajouter un commentaire
5 Réponses
Solution retenue
Hello Madison
Just like gatewaynomad said to make the instruction easier we will need to know what version of Windows your laptop is running.
Saying that resetting the Offline Windows password isn't to hard. Note that I said Offline password. that is because if you are using Windows 8 and above you can log in using your Microsoft Account password or any other online account password. If you have used an online account password to login, then you will need to reset your password using that online account reset password feature. If you let us know what online account you used I would be happy to provide you with a direct link.
If you used an offline password the you can follow the below instructions to reset it.
  1. Boot you computer to the login screen.
  2. Hold down shift while clicking the restart. This will then open a OASO (Advanced Startup Options)
  3. # If you can't access the Advanced Startup Options I will then have to tell you how to make a bootable Windows recovery USB or DVD.
  4. Touch or click on Troubleshoot, then Advanced options, and finally Command Prompt.
  5. Type in the following net user then your username and then a space and your new password (the new password your want to use). So if your username was David Lindner and I wanted the new password to be password the command should look like this net user "David Lindner" password If there is a space in your username please place speech quotes at the beginning and end.
  6. If you can't remember your username or get an unknown user type net user to list all available users.
  7. Now restart your computer and try the new password we just set.
I hop this help.
Indice 6
If you forgot a BIOS password, you can remove it by unplugging the battery for a while. If you forgot a Windows user password, it can be reset your password with Windows install CD. The last resort is format your hard drive and perform a clean install.
Indice 1
2 commentaires:
How do you format your hard drive and preform a clean install?
par
Melissa This would be done by reinstalling the OS from some form of installation media such as a recovery USB CD or DVD or a windows installation disk.
par
All I want to do is to change the password
Compaq presario cQ57
Indice 0
1 commentaire:
I would like to change my password on my compaQ laptop. Presario CQ57
par
On start : look on screen bottom may say F2 startup. On Bios. Look for password set up.
Indice 0
* Tried but I failed, I'm using offline
Indice 0
Ajouter une réponse
Madison sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 10
30 derniers jours : 45
Total : 12,097
