Thanks for the question.
This could be any number of issues. From a 'simple' replacement of the lcd to full on motherboard damage.
The question is, do you want to put time and or money into the tablet.
If this is NOT a repair for a customer and just tinker fodder then I would start with the LCD as the source of the issue. This, is more than likely wishful thinking however. The big red flag is the fact that the Android logo didn't go away. You could be looking at board damage. If you are hopefull for the repair then move on to checking things like power. (Which you seem to have started that process with the consideration of the charge light)
If it IS for a customer then make sure, before anymore effort is spent on it that the customer weighs the costs of repair AND replacement of the device.
Tablets under the 100 dollar price tag are notorious for dieing out of nowhere and being too expensive to repair. Especially when comparing how much it would be to replace outright to repairing an lcd, digitizer, battery, connectors, or chassis. If the motherboard is damaged then just move on.
My suggestion would be to just let it go. You could buy a good tab to suite your needs for probably the same amount it would take to pay to fix this one. Even if you are repairing it yourself.
Hope this helps.
Good luck.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
