Aller au contenu principal
Annoncé en mars 2015 et mis sur le marché le 10 avril 2015, le Galaxy S6 Edge est la version à écran incurvé du tout nouveau téléphone phare de Samsung.
Cant register network/no signal, after 'water damage'
Just recently dropped my s6 edge into a river, worked for awhile then switched off. Pulled apart my phone, alcohol cleaned it and replaced my battery, now all is working except my phone signal. My sim card works in another phone so i'm questioning what part do i have to make certain is ok apart from the antenna cable and how i can go abouts testing it out. I will reseat the antenna cable although i would like to know what other antenna associated parts i have to play with. I know its not software since i already checked that. Thanks!
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
I have the same problem, did you find a solution for it?
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
I can say that you have to clean very carefuly the board. Alcohol is good but i will prefer Isopropanol or isopropylalcohol. After clean you can check this parts below and two cables between them:
Indice 2
2 commentaires:
thank you! I cleaned the parts, but now i can only use GSM or 2G only on mobile network settings. When i choose another option i do not lose connection with the provider or the sim, but i cannot make calls, go on the internet or send a text message. I checked the APN from the provider, my IMEI number is not corrupted or something.
Like to hear some suggestions
par
Can you post a clear pic from the charge connector flex cable?
par
Ajouter une réponse
James sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 5,917
