Aller au contenu principal
Sorti le 19 septembre 2014, cet iPhone avec un écran de 4,7 pouces est une version plus petite de l'iPhone 6 Plus. Identifiables par les numéros de modèle A1549, A1586, et A1589.
Questions au sujet de 5199 Voir tout
Faulty home button, doesn't work
My friend has an iPhone 6 which I refused to fix because of the home button issues. His home button doesn't work at all so needs replacing but can't do that because when it's updated it will get error 53.
The phone is under warranty but had a screen replacement
I could swap an original lcd back on and claim under warranty
Failing this, does anybody have any alternatives or any other way?
is it possible to swap the components on the flex cable onto the replacement?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
4 solutions
Solution retenue
There is no alternative, original home button only.
They may be having issues with home button because of the extended cable under the shield, try replacing that first, because if that gets damaged it causes issues with the home button. If that fails, then only thing you can do is try and put an original screen on, clean up all the inside to make it look like it hasn't been opened, they may or may not replace it.
Cette réponse a-t-elle été utile ?
Indice 1
Well that's not exactly true. You need to keep the original, unworking home button, for when you do updates. As long as the original home button is in there, it shouldn't get error 53. The rest of the time you can use the after market button
Indice 1
Commentaires:
Yes I know that but that's not really fixing the issue, is it? I'm not going to put a button on the phone that they can't update etc. It would require constant support from me and is not worth doing
par
Well the customer needs to weigh the pros and cons of the situation. How much is the phone worth? If it gets error 53 it's bricked. How much would you be willing to charge to put the old button on and update it for them?
par
i'ts posbile but even if ou menage to do it, nobody knows how long will it work
Indice 0
Error 53 is a vestige of history. It is no longer a problem since Apple released iOS 9.2.1. As long as you're not running iOS version 9.2.0, you shouldn't see error 53. See https://techcrunch.com/2016/02/18/apple-...
Indice 0
Ajouter une réponse
James Carter sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 411
