blue spot above home button after battery replacement
I replaced the iPhone 5s battery following step-by -step guide from ifixit.
I have two problems:
1. the screen is a little bit mobile and not completely fixed to the base/assembly.
2. A new bluish area ( size of thumb print) is on the screen ( when phone in use) just above the home button.
phone is otherwise working fine. I am letting the battery drain below 10% before charging it fully. so not sure on the battery yet.
what should i do to fix the problems?
2 commentaires
I also have a blue spot at the tope left corner. Before disassembling mobile it was in another place, so it moves like a ghost. Will it disappear? How did you solve it?
par Lorenzo Pons
Im interested in it, because under charging, I have blue area on the middle left side.
par akupressz
