Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Questions au sujet de 79 Voir tout
Takes several retries for image to stabilize, logic board not at fault
Weeeeird problem.
Recently, when I would turn on the screen, after a brief flash of the video output, it would go dark. Several retries (switch off and back on) later, it will switch on and stay on for as long as there is power. If it switches off either straight from the power source or the OS settings, I have to do the same thing again.
I followed the troubleshooting guide here and ALL the voltages were correct. I checked all boards for anything suspect and found nothing. So I went ahead and ordered a logic board.
I just replaced the board and guess what? The problem is still the same, exactly.
Is there any chance of repairing this screen without spending more cash than buying an equivalent? (logic board was ~$100 + very expensive international shipping).
Thanks
Georgios
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
I'd try replacing the internal video cable that exits out the back of the display. They are notorious for failing and causing odd video issues like you described.
Cette réponse a-t-elle été utile ?
Indice 0
Commentaires:
I'm gonna kill myself if that's the case :) Are there any standard cables I can use for this?
par
Ajouter une réponse
Georgios Diamantopoulos sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 72
