Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
3531 questions Voir tout
Phone dies at 20%
I recently got a used iPhone 5s from my aunt. It is running iOS 9.2.1 and everything works fine exept for the fact that the phone will die with 27%, 25%, or 20%. When I plug it back in to charge the phone turns on again with the same battery percentage as it had when it died. Is this a software or calibration issue or do I need to replace the battery?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
i had same issue with my 2 years old phone, at 30% it will totally shut down, what i did is i replaced the battery, now everything is perfect. i used the ifixit battery replacement kit
Indice 1
I would try putting the phone in DFU mode and updating/restoring it.
Let the phone die and then charge to full
If it happens again the battery needs replacing
Indice 0
Usually happens when you don’t charge your phone often or the common one, the battery may be old or not working. You can charge it to full and kill it again over and over til it works.
Indice 0
Ajouter une réponse
Vince Parisi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 5,742
