Aller au contenu principal
Guides de réparation et support pour les téléphones produits par Jiayu.
8 questions Voir tout
Phone dead after connecting wires to wrong pin on micro usb charger
I was in an emergency situation where i needed to charge my smartphone and i only have a broken usb wire and a mirco usb conncetor. I connected the positive and negitive wires to the pins on microusb connector. it worked fine for a few seconds but unluckily the positive wire slipped and connected to one of data pins. The phone turned off. Now as soon as i insert the battery the phone blinks every time i press power buttton and led light turns on or blink in 2 different colors.
I need to ask what parts could possibly be damaged or how can i check the damaged part as i cant sent it back to china to repair and prefer to order the damaged part instead.?
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
@mtk there is not a particular part that will have failed. Any of the components along the dateline that got powered may have failed. Unless you disassemble your phone, have a schematic and a board layout, there really is no way to fix it.
Indice 3
if i change the power acpi or motherboard can it be useful in the same case
Indice 0
Ajouter une réponse
Muhammad Tehseen Khalid sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 573
