Aller au contenu principal
A 16 megapixel resolution video camera made by Bell and Howell. It was manufactured in 2011.
Questions au sujet de 2 Voir tout
Why won’t the screen on my camera turn on?
The camera is turned on but the screen won't turn on.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
4 Réponses
Réponse la plus utile
The screen on your camera may not be turning on because the battery in your camera is low and needs to be charged. Another possibility is that your screen is actually on but the brightness setting on your camera is too low for you to be able to see the image. You may also be trying to use the camera at night or in a dark setting and the night vision mode needs to be turned on in order for the camera to pick up clearer images.
Indice 1
If the internal screen will not turn on there is a chance there is a faulty connection either to the battery or to the input of the screen from the camera. Of course it could also just be the screen itself that is broken or cracked. To correct this you will have to check the connections to the screen and if that is not it a full replacement might be in order.
Indice 0
I also ave this problem. The screen comes on for a few moments then goes blank after displaying a
legend "power is depleted". I have tried charging the batteries overnight and using fresh batteries and still get the same result .
Indice 0
1 commentaire:
My screen comes on n stays on and it's sayslizard cam bulb head .com but the camera never shows anything
par
I have the Sam problem except my screen won't come on at all I press the power button and it lights up green then goes off
Indice 0
Ajouter une réponse
Jerry Hadjah sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 25
Total : 2,012
