Why won't my drill operate?
When I push the trigger, my drill will not operate at all.
If your drill will not operate some things to check are if the batteries are low or may be dead. If the batteries are not holding charge you may need to purchase a replacement battery. Also your brushes attached to the motor may be old or have dirt built up which can be replaced by following a replacement guide. The motor, which is the main source of power, may be burnt out. It can be replaced by following videos or replacement guides or the connections to the motor could simply just be dirty. So I recommend wiping down the connections and seeing if that helps.
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 381
