Aller au contenu principal
Console de jeux de 3ème génération de Microsoft, lancée le 22 novembre 2013.
727 questions Voir tout
Xbox one Controller wont sync
My xbox one controllers wont sync no more. When i press the console sync button it wont flash or anything. it only works when i have it wired but cant use it wireless. i had a new ribbon cable replaced in it and still dont sync. could it be my rf module or the wifi board? and can you tell me the functions and symptoms of them? thanks
Répondre à cette question J'ai le même problème
Indice 5
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Remove batteries and connect controller with console via usb. Go to settings and there is a tab for controller inside that there is even a button for updating your controller with the latest firmware. If there is an update then do it. Turn of console, use NEW double A (AA) batteries, not the one you can recharge, single use batteries. Put them inside controller then connect controller with cable onto XBOX ONE, hit XBOX ONE power button. Your controller will vibrate for a moment. When XBOX show dashboard (homescreen) try controller. If does not work press the XBOX button on top of the controller. If it works then remove cable connecting controller with console. If controller turns off (the xbox logo on top turns off) then there is problem with controller if not there is problem with XBOX ONE console.
Hope this direct you to the problem and then fix it!
Best of luck!
Indice 2
1 commentaire:
Thank you some much you have saved my weekend!
par
My xbox isn't syncing with usb at all
Indice 0
Ajouter une réponse
Jeremy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 8,489
