Aller au contenu principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Questions au sujet de 566 Voir tout
replacing silver bezel screen with black glass screen
Hello
I have macbook pro 15 early 2011 with silver bezel screen , can i replace the screen from silver to black glass screen?
Update (04/21/2016)
it will be good if i just remove silver bezel and put glass on?
Update (04/22/2016)
yes its a1286 higher resolution screen thats why it have silver bezel without glass but i hate that look i prefer black bezel with glass. is it possible?
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
2 réponses
Solution retenue
While its possible to replace the cover glass you may not like the look. Apple doesn't sell the glass this is a reproduction. It is also Glossy (no anti-reflective glass). If you have the matte finish hi-rez screen you have the best screen in my opinion. The glossy screens are hard on the eyes outside or when you're near a window.
Frankly, I would leave it be. Don't forget if you change the bezel people won't believe you have the better screen if you try to sell your system (lowering its value).
Here is one source: Unibody Macbook Pro Glass Screen Cover Replacement this one has the Black Bezel.
Follow this IFIXIT guide to take the display off: MacBook Pro 15" Unibody Early 2011 Display Replacement. Once you get the display assembly off you'll need to follow this guide MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement. While not exactly the same model as yours the steps needed to replace the cover glass is the same. Jump to Step 14 and follow it to Step 21. It's very easy to melt the rubber gasket with the heat gun. Getting a replacement will be difficult so be very careful!
Again, this could end up being a very expensive mistake! Make sure you have reviewed things as its very easy to damage things here.
Image MacBook Pro 15" Unibody Late 2008 and Early 2009 Écran LCD
Tutoriel
Remplacement de l'écran LCD des MacBook Pro 15" Unibody fin 2008 et début 2009
Difficulté :
Très difficile
Image MacBook Pro 15" Unibody Early 2011 Écran complet
Tutoriel
Remplacement de l'écran complet du MacBook Pro 15" Unibody début 2011
Difficulté :
Difficile
45 minutes - 3 hours
Cette réponse est utile ?
Score 2
Réponse la plus utile
Here's the one I use for this. I like it because both sides have a covering eliminating a lot of cleaning time: http://www.ebay.com/itm/New-Apple-MacBoo...
UPDATE
I'm not sure if we're talking about the same thing. Your references seem to be about an older type model that did have a silver frame. Please see if you can find the Axxx number on the back and let us know what it is.
Score 3
Commentaires:
@Mayer - The silver bezel'ed systems have the higher resolution screens in this series. I suspect she just likes the black bezel look :-)
par
Ajoutez une réponse
Le' Aetheria sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 642
