Aller au contenu principal
La Magic Mouse est une souris multi-touch fabriquée et vendue par Apple. Elle a été annoncée et vendue pour la première fois le 20 Octobre 2009.
52 questions Voir tout
What can I use to stick back together the mouse?
I disassembled the mouse to fix the bent aluminum from dropping it and it works, but sticking the bottom part to the plastic battery tray is hard. What is strong enough to hold the plastic and alunium together?
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires
Do you mean the entire bottom panel, or the battery cover? Refer to the Magic Mouse teardown guide and tell us which step number illustrates the part you're trying to reassemble. Step 3 or Step 6?
par
The battery cover is OK, what I meant is the bottom panel https://d3nevzfk7ii3be.cloudfront.net/ig...
step 6
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
After cleaning off the old glue from both sides I would recommend just using hot glue as it's fast give it a good 15 min and it's done.
If you don't have access to a glue gun then a few dabs of clear silicon adhesive will do but you'll need to use a few rubber bands to hold the parts together to setup for a good 24 hrs.
Indice 3
Ajouter une réponse
Vitaly Bugaychuk sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,354
