Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
The Gold Wireless Stereo Headset delivers amazing depth and audio clarity, elevating your gaming experience with custom audio modes created by developers exclusively for PlayStation®.
Questions au sujet de 20 Voir tout
I need some real help with my headset
My headset does not want to turn on and connect to the wireless adapter. It is charged and has no problems with anything else because I use it with my phone connected to the cable and it sounds good it just will not turn on wirelessly. Please help
Répondre à cette question J'ai le même problème
Ajouter un commentaire
Kits pour Nintendo Switch
Une solution rapide pour reprendre le jeu
Acheter un kit pour Switch
2 solutions
If that is a Bluetooth Headset you have to make sure it isn't connected to anything else. Bluetooth is single stream only and will not work if it is already connected to something else. Like your phone. Disconnect it and make sure the headset is not connected to anything, then connect it to the Bluetooth wireless adapter.
Cette réponse a-t-elle été utile ?
The answer above is the most common I've run across but in a few cases a step in setup is overlooked. Besides plugging in the adapter for any first time use this set needs to be plugged into the console once as you would a new controller and then it's works perfectly especially when using headset companion app. Depending on preference in the settings you also need to change sound output to all audio from just chat and turn TV volume off completely to avoid echo. Excellent headset for the PS4 and 3
Ajouter une réponse
JOSH 08 sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 389
