Aller au contenu principal
Connu sous le nom de ''PS2'', c'est une console de jeux vidéo de sixième génération sortie par Sony au Japon en Mars 2000. Elle sera disponible plus tard aux États-Unis dans l'année avec la SCPH-30000. La réparation de cet appareil ne nécessite que des outils communs, mais peut s'avérer compliquer.
Questions au sujet de 163 Voir tout
Realigning a new laser in SCPH-30001R
Hi Everyone,
I recently replaced the laser in a SCPH-30001R, and realigned the laser so that it could read discs. After I realigned it though, it would only play PS1 discs and blue PS2 discs. When I would try to test a silver PS2 disc or my laser cleaning disc, the drive would making buzzing noises. (Versus no buzzing at all with the PS1 and blue PS2.) Should I keep trying to align it, or I'm I missing something? The laser model is a KHS-400C, the same model that I found in the system before replacement. When I first installed the laser without any adjustment to the laser angle, the system would not load any discs.
On a side note, I have another SCPH-30001R, that takes longer than normal to load a disc. Is there anything I can do to improve the load time?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Solution retenue
@supportninja you can try to further adjust the laser and see if that will work. Of course it will also depend on how your are adjusting it. Take a look on here as well as the answer Disc is not spinning with a new laser PlayStation 2 for that. There were issues with the laser and the alignment on the PS2.
Cette réponse a-t-elle été utile ?
Indice 3
Commentaires:
I think I know what the problem is now - When I installed it, I am fairly certainly I screwed in the angle screw on the rod all the way. I'll give adjusting it a try and post the results.
par
Ajouter une réponse
Ben Eccles sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 20
Total : 1,567
