Aller au contenu principal
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Questions au sujet de 232 Voir tout
My Touch screen broke
My touch screen only work with spen, not when I touch it with finger, on the left side of the screen it works a little
Une réponse ! View the answer J'ai le même problème
Commentaires:
Thank you guys so much
par
Ajouter un commentaire
2 réponses
Solution retenue
The S pen will work separately from the digitizer because the S pen function is being sensed by a film like sensor behind the screen/LCD. If you are getting no touch or half touch capabilities from the screen you have a bad digitizer on the screen assembly. You will have to get it replaced or replace it yourself using one of the guides featured on this website.
Cette réponse est utile ?
Frank is correct on this. it looks as if you have a digitizer problem. With a little know how you can order a replacement and fix it. there are guides on this site on to how to do this. If you go to the manufacturer though they may charge you a few hundred dollars. if you do it yourself or have someone you know that is capable do this then you can order the part for around $100 and then fix it. I know that for an Iphone apple is charging somewhere around $300-400 to replace the digitizer. I hope that is helpful and you are able to get your phone in working order soon.
Ajoutez une réponse
Michael sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 170
