Top row of keys backlight don't light up (every other key).
Hello everyone! I have a 2014 MacBook Pro Retina that I'm trying to repair. The computer was water damaged and everything worked fine except for the top row of keys on the keyboard, what I mean by that is the backlight was the problem. Starting with the esc, F2, F4, F6, F8, F10 and F12 keys, the backlight is not on at all. So I figured the keyboard was the problem (since it was water damaged.) I bought a new top case and installed it, everything works fine but again the same keys don't light up. What can be the problem? I checked for corrosion on the backlight connector on the logic board but nothing is there, I cleaned it out with Isopropyl alcohol as well. Thank you for your help!
6 commentaires
Last four digits of serial number are: G3QH
par Cyology.IO
Due to a change in EveryMacs policy we can no longer tell which machine this is by the last four digits. Please go here and enter your complete serial number:
http://www.everymac.com/ultimate-mac-loo...
par mayer
See if those keys work with an external keyboard.
par mayer
@mayer? What do you mean, the buttons on the keyboard all work 100%, it's just the backlight won't work for those specific keys.
par Cyology.IO
@mayer
MacBook Pro "Core i5" 2.6 13" Mid-2014
That's the notebook, any help would be appreciated greatly. Thanks for your time!
par Cyology.IO
Afficher 1 commentaire en plus
