Aller au contenu principal
Screen can't use it
My touch screen I can't do anything with it????it just gos nuts
Répondez à cette question J'ai le même problème
Score 5
Ajouter un commentaire
Fix Kits pour Android
Remplacer l'écran ou la batterie est à portée de kit !
Acheter maintenant
Acheter maintenant
4 solutions
Hello Marvin
It sounds like your digitiser might be faulty.
You can buy a new one from here.
You can see a screen tear down from here.
Hope this helps.
David
My Computer Dude
Cette réponse est utile ?
Have you tried resetting your device? What about performing a firmware update? If problem still persists, open up the casing and check the ribbon cables. Make sure they are tight and snug (make sure your device is powered off while performing this step; will void your warranty). If the problem continues to occur, most likely your touch screen digitizer is faulty. It is relatively easy and inexpensive to replace (replacement panels start at around $8 on eBay or any other retailer). When buying a new panel, ensure that model and version number matches yours. Hopefully this helps.
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
My screen won’t work and I can’t get in
Commentaires:
And it’s cracked
par
Ajoutez une réponse
Marvin sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 886
