Aller au contenu principal
Repair manuals for tablets manufactured by Samsung, running operating systems other than Android.
Questions au sujet de 61 Voir tout
lcd show weird colors
Hi there everyone,
''So i repair for living mostly i find by myself what the problem is but with this one i got no idea what i could be.
so i got an client with a Samsung tab Model; GT-N8010 he come over with this tablet showing strange colors (like the colors are negative) on the lcd.
no problem i replace the lcd , everything worked perfect colors are perfect.
after 2-3 weeks client comes over again with the same issue, ofcourse hes little bit mad because he payed the repair.
thing i hope you can do answer for me:
''-can it be from dropping the tablet on ground?
-could it be lcd cable?
-is it an hardware/software problem?
-did someone experience this ever before?
thing i tried:
'''-factory reset
-soft reset
-try to put negative colors on to see ( that even worse)
sorry for my langue (im dutch)
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Clean LCD cable with isopropyl alcohol. At least 90% or better with battery unplugged. Make sure you definitely tape the LCD ribbon cable / connector down to reduce chances of it moving around.
Hardware problem. Most of the time it is the LCD cable. You probably didn't need to replace the LCD if you didn't try cleaning / replugging it firstly.
1. Can it be from dropping the tablet on ground?
Yes that is very possible.
2. Could it be LCD cable?
Yes, another possibility.
- Is it an hardware/software problem?
Hardware issue.
- Did someone experience this ever before?
Yes. Have had a few clients come in with this issue. I solved it by replugging / cleaning the LCD ribbon cable and making sure there is a sufficient amount of tape so that the cable / connector can't move around.
Indice 2
1 commentaire:
thanks for the reply, gone order new lcd cable , already tried to unplug and with 99% isoprop so i guess last chance is lcd cable otherwise hardware or client droped tab...
par
This is a problem with the LCD screen. Here is one: http://www.ebay.com/itm/for-Samsung-Gala...
Indice 0
1 commentaire:
i don't think so, i replaced the lcd and the same problem just returned after 3 weeks.
par
Ajouter une réponse
Brian ifikske sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 21
Total : 336
